themechanic
Oklahoma is OK
- 2:27 AM
- Nov 11, 2012
- Moore, Oklahoma
This might save a life.
You're supposed to cross-thread them and run'em down with the impact driver on old cars.I just replaced my upper control arms on the Coronet and, in the process, found both bolts had come loose on the driver's side caliper bracket.
Torque to yield bolts have a built in malleability by design . They STRETCH ….Why build in what will be a failure point for DYI'rs and untrained/unknowing mechanics? Most cars are built without torque-to-yield bolts on the calipers and they function just fine. What benefit of using these bolts outweighs the risk of bolt failure when they fail to get replaced? It's a failure of basic engineering practice.
Thanks for posting. I didn't realize the world had reached this level of stoopid yet. It's getting hard to keep up with.
That is not necessarily true, the issue here is when it starts to first "yield", which I already defined for this discussion, and when it fails can be rather far apart, meaning when it starts to "neck" down it is becoming thinner in cross-section and ultimately weaker.I really don’t understand TTY bolts anyway. If you tighten a bolt to a point where it yields you have already made it weaker. Just put regular f’n bolts in stuff and be done with it.
I agree with gtxdana on this.It's highly unlikely the bolt that the man-bun wearing, internet sensation was waving around would even be used to secure a caliper torque member to an upright.
Just because a bolt torquing procedure lists an angle value doesn't necessarily mean the bolt is a one-time use torque to yield bolt.
An angle torquing procedure is used to ensure the proper clamping load (stretch) of a fastener taking out the effects of friction from dirt, rust, oil, thread locking compound, etc. on the final torque value.
A threaded fastener moves a certain amount per degree of rotation. In the angle torque procedure, the fastener is tightened to a lower torque value before excessive friction comes into play, then the fastener is turned a set number of degrees which results in a more consistent stretch of the bolt.
If the fastener is a one-time use item, the service manual will spell that out in the repair procedure.
I agree with everything except the last sentence. There should be required a marking on the bolt (a big star?) that indicates it's a one-use bolt, end of story.It's highly unlikely the bolt that the man-bun wearing, internet sensation was waving around would even be used to secure a caliper torque member to an upright.
