Odd 383 Distributor Cap (With Breather Hole)
Mariposa Mike
9:55 AM
Mariposa, CA
Recently replaced ignition parts on my 66 383HP Charger including the pictured black cap. Never seen one with a breather. Standard brand I believe. Anyone else seen these and have an explanation why it would be needed? Pertronix electric ignition if that matters.
The vent on the pictured cap is to relieve buildup of ionized gases, from the arcing of the rotor tip to the cap contacts, inside the distributor. The addition of the vent to replacement caps started in the 1980s.
Breathers on distributor caps are common, they started appearing way back in the 70's as the energy delivered by ignition systems increased there was issues with high voltage causing ionization of the air trapped under the cap.... To be honest I don't understand the physics of it but here's a link...
Google Search
Basically the manufacturers were fighting ignition misfire issues and venting the cap solved it...
So apparently my memory is fine & I didn't just pull all that outta my butt.... :rofl:
And I still remember seeing them first in 78-79 time frame..
Holy Moly. I can create plasma in a distributer...and ions, atoms, electrons??? The 70's were different times. Maybe this theory came from some guy smoking something at the corner of Haight and Ashbury. Seriously though there must have some data that led to this. Maybe electronic ignition systems don't have this issue and they generally started in the mid to late 70's. Thanks for the explanation though. Like I say, never saw one before.
I always wanted a clear distributor cap. :D
My 95 Caravan had a OEM cap with the vent. Went a very long time. Subsequent caps had no vent and never made it past 10,000 miles. I learned to wash the ionized deposits off and dry them out in the oven. Got to the point I could immediately tell when it was time to change the cap and always had a spare with me.
A clear cap would be very cool. Could stand there for hours and watch all 8 firing off over and over. Back in the day I never had an issue with a cap. Especially going only 10K miles. I did have issues once in awhile with the dual points. Recall one time going over Tioga Pass in Yosemite in my 67 440/375 HP Sport Fury. It began missing as I got to the upper altitude and ran fine after I dropped elevation. Turned out one set of points gap had closed down to about .010 and were slightly burned with a tit on them. Why that only showed up at altitude I don't know but adjusting them solved the problem until I could change them out.
Mystery solved! I always wondered where those extra ions were coming from in my garage.
Probably due to the air fuel mixture getting so fat at altitude the weak spark couldn't fire certain particularly rich cylinders...
Was it a 4 speed?
It was not. But was the fastback model like the Chrysler body and a really great engine. L code I believe it's called. I would still have the car today except I did not order it with A/C and at the time after market A/C was not an option. Had it for 10 years. Still have the order form the dealer filled out. PS, power disk brakes, which also was not ordered originally but Chrysler Corp would not build the car w/o disk brakes so I got a call from the dealer saying they would split the cost with me. $40 my cost. Turquoise with black interior, center console, trailer towing pkg, clock, remote mirror, rear speaker. Due to the 440 it was a special order...not cancelable. All for $3421.19. Sales tax $135 and DMV $57. CA purchase.
I know all you asked was it a 4spd. Could not help but go down nostalgic road. Forgot to add a AM radio as well.
No that's great thanks. Very cool story. I have an L code 4 speed 68 Monaco 500. QQ1/ black top. I was just curious about the auto coming with a dual point.
Yours came with chrome valvecovers I presume?
I like the fact that you still have the order form.
I am working on a 67 L 4speed now. GG1, I imagine yours was LL1.
Jon Gibbs is trying to find all the 66-7 Chargers he can. He lists them all. Even wrecked ones.
Please consider sending a picture of the dealer order form and any other information to him.
Remote possibility that your old car might be out there.
FastbackJon@gmail.com.
I sent him information on our L 4speed. Our driver auto, and a burnt one. Also a friends L auto, another 4 speed, another 4 speed.
I have corresponded with the original owner of our GG1 that he ordered after a tour of duty. Have his certicard. He doesn’t have any pictures of the car from 1967 or later. Told me his wife hated the car, think he traded it off about 1970.
Mariposa Mike's car is a Sport Fury
Both the 67 and the first new car I bought, a 1963 Plymouth Fury with a HP383 and a 4-spd had the dual points. Have a couple project cars now, 1964 Chrysler 300K models, that have the 413 autos and have dual points. Another K is a X-Ram car auto with dual points. Also a project car. So it seems that was typical.
