Is this junk?
koosh
8:42 PM
CT
And would i need to change any wiring for amps purposes?
Under Specifications above, it says 55W?
Listing for bulbs said 105 Watt. If 55,Watt your talking about 4.58 amps per bulb. So about 18 amps total for 4 bulbs. If memory serves me the light circuit is on a 25 amps fuse or breaker.
Before purchasing...
Suggest U check their depth measurement...
Many of the off-shore products require modifying the headlight mounting bucket for clearance..
Just my $0.02... :thumbsup:
Thats my problem…. budget??? Long blown…
Im there with you. These dam clips for a charger will kill you. I dont drive my cars at night do to special people on the road.
Make sure they are DOT approved otherwise you risk blinding someone and having them hit you because you blinded them... Folks with astigmatisms have worse trouble with LED headlamps. There are good options respect oncoming traffic.
Just do a 12v headlight relay upgrade and stick with the stock lamps. It's makes a huge difference and as a benefit takes load off your 50+ year old light switch, bulkhead connector, and wiring, and can be done for just a few dollars. If you don't like the non-stock look of the relays, they are small and easy to hide. It's a no-brainer!
Can you explain more and where to get?
Member @Crackedback over on the A-bodies only site sells a headlight relay kit that does exactly what #41 says above.
Not sure if he posts here as well or not.
I have the chineasium relay kit I got from E-bay on my Runner - works great.
Do you have a link to that relay kit?
I’ve checked Mr Crackedbacks kit…. Too much $$ for me.
And do these kits work for Wagner halogen lamps ?
