Sparky Anderson
The only problem is if you have a short in the system, your car will light up like a Roman candle. There's a reason why if you go to a higher amp alternator, you should increase the cable size to match that. Take it from an electrician.You won't 'cook' your wires with a higher amp alternator, it will still only put out what is required. Just like if you had a 60 amp home service breaker box in your house and upgraded it to a 200 amp box, your wires wouldn't get any warmer.
