A727 Neutral Safety switch oddity...
GassMann
12:10 AM
Pullman WA
Hey all,
I have an odd situation I need more eyes on. I rebuilt the transmission during a full rebuild a few years back. I did not replace the neutral safety switch. Since the overhaul, I have had issues with starting ONLY in park. In neutral, it will start. In park, it has to be in an EXACT position to start and sometimes even that does not work. Down under the car, I can feel the selector compressing the switch, so I know it is making contact.
OK... ohmmeter time. In neutral, ohms are zero... full contact. In park, I get somewhere between 99 and 191 ohms?!? Wiggle the selector JUST right, and I get zero ohms. WTF??? How is that possible? I mean, the switch is just a simple rod connected to a spring connected to the post. Spring compressed... i.e. park or neutral... contact is made. Reverse or drive, switch spring is NOT compressed. I pulled the switch, tested the ohms on the bench through travel. No change so it can't be the switch. If I replace the switch, I fear it will produce the exact same scenario.
Has anyone seen this before??? Any ideas on what the hell is going on with this?
Thanks in advance for any insights you might have.
What kind of shifter?
Cheetah shifter in my race car. Fought the exact same issue on and off for over 20 years. I finally solved the problem once and for all.
Not for the faint hearted, but I put a limit switch with a cam in the shifter itself. Works great.
Sometimes, the column/console shift mechanism can be a little sloppy, and cause issues like this.
I would UNHOOK the shift linkage from the transmission lever, and repeat your tests of the neutral safety switch (NSS.) Pulling the lever all the forward (into Park), you should feel and hear an audible click, as the rooster comb and parking pawl engage. Move the lever rearward one notch, and it snaps into Reverse. Continue rearward as it snaps into Neutral. Test the NSS at each of these points.
Repeat as necessary to assess: each time it snaps into Park, is the NSS testing correctly, and accurately? If not, you may need another NSS. If it's not the NSS, then you may be looking at dropping the pan and valve body to inspect and correct.
Now, if the NSS and shift linkage test reliably, your looking at an issue with the shifter linkage. It seems a common topic that some of the plastic bushings break, or there is wear, causing some shift abnormalities.
The transmission is in my 66 Charger with standard shifter. Nothing special. The linkage is aged... as one could imagine. But the linkage is doing what it needs to do... shift from drive to park. The pall is in when in park and locks the rear end, so I know the leaver is set right.
Tighten switch 1/8 turn. If no good, get a new switch.
Thanks Rishi... I did exactly that to test it. So you think it's the switch?!? I currently have the single pole, long body switch.
I will try that. I actually purchased a new one but at the time, I did not know there was a short and long body. The short is what I got so no go there. But looking online, all the options for long are 3 pin units. Though, even that is confusing because the text reads LONG PIN... so does that mean it's a long body or are the f'ing pins long? I think, I can use the 3-pin long unit and just wire up the center pin. Anyone know if that is correct?
I have successfully in the past adjusted the knob on the shifter until it worked correctly. Then set the set screw. Learned that about 1970. Don’t remember where i read that information. It would apply to all console automatics , A, B, C bodies that have the chrome shifter knobs.
Possibly try this.
Loosen the set screw in the knob.
Put the handle in neutral.
Turn the knob one way or another, until the button is flush with the housing.
Shift the lever to all positions and see if the button pops up.
Start the car. Shift through all positions. You might want to keep your foot on the brake.
Possibly try this.
Thanks 440... I will give that a try. :)
Any updates to this? I am curious because I’m also having some issues with my NSS.
My neutral safety switch is working correctly but no reverse lights.
My reverse lights sometimes makes contact on the shifter between Park & neutral. I’m getting a new switch tomorrow just to try, but I’m not looking forward to swapping it out.
1970 Satellite 340/904 original
