Neutral Safety Switch - Reverse Lights on in R, D, 2, and 1
digi_d
8:08 AM
Seattle
Hey all, hoping for a little guidance or ideas here on my 69 Super Bee with a 727. Problem is as described in the thread title - here's some additional detail:
-Car has 40K miles on it, I'm the second owner and have solid knowledge about what's been previously done
-NSS & transmission internals are original
-I finished rewiring the car last month (engine harness, dash, and forward. Rear harness comes in next week)
-This issue popped up after rewiring
-Car starts in P & N and (as expected) will not start in R, D, 2, or 1
-Shift linkage is a bit sloppy, all positions work as expected except shifting from shifting from N to D keeps the car in N. I have to go down to 1 then back up to D to engage D
-Reverse lights do not turn on in P or N
From what I can tell in previous posts culprits are typically rooster comb, the NSS, or shift linkage adjustment. Please correct me if wrong but...
-If the linkage was out, wouldn't I be unable to select the correct gear and/or have starting issues?
-If the NSS was bad, wouldn't it give me no reverse lights at all or reverse lights on in all gear selections?
-Given the car has it's original rooster comb and NSS, I can't see it being a length or parts mismatch issue
At a bit of a loss here for further troubleshooting - any other input is welcome!
I would test the switch. Eliminate all issue with wiring, disconnect the harness from the switch, and confirm the switch works correctly for each gear selected. Those outer pins will connect only when in R. The inner pin is only grounded when in P and N.
While you acknowledge the wiring has recently been fiddled with, and that may very well be where the problem lies, in the past, I've gotten myself all spun out on a wiring issue like this, because I failed to confirm the things like the switch were in proper working order.
Thanks for the input guys, I’m taking a look at it presently. Interestingly, when I pulled the plug off the switch, the boot was full ATF.
Good call on specifically testing the switch, I think that’s it. The two outside pins have continuity in R, D, 2, 1 but not in park or neutral. I’m understanding the wiring diagram correctly, those pins should only have continuity in R.
from memory, the center pin grounds in R to complete the backup lights circuit.
Well the three new switches I bought all behave the same as the one that came out.
Put a scope in and I think it is indeed a rooster comb problem. Looks like I have the middle one in this picture:
If I’m understanding correctly, this would not work with a 3 prong NSS. I’m a little boggled about why it’s even in there.
Decided to cross check the serial and sure enough, 2801543 is a 67-68 code.
So now to figure out if I can just swap out the rooster comb over to the later style.
So I have a question. I see a different switch listed for 68 - 77. It is the longer body one below. The one on the right in the picture seems to be listed for 77 and up. Do they operate differently or is it just a difference in size?
Just closing the loop here after chatting with a few local transmission shops as well as Cope Racing Transmissions. The mechanic's consensus is to buy a new valve body and install that. Doubly so because I have a 69 Bee with a 68 transmission and the 68 valve body doesn't support partial throttle kickdown whereas the 69 does. Looks like it'll be this unit:
https://www.coperacingtrans.com/?product=727-904-pro-street-automatic-shift-valve-body-1969-up
Going to add a rebuild/refresh kit as well. From here, I need to make the decision around doing it myself (ugh) or having a local trusted shop do the work. I'm extremely curious to work on an automatic transmission but with limited space, resources, knowledge, and for piece of mind's sake, I'll probably have a professional do it.
I'm certainly no authority but, from my research over the last couple weeks, with 3 prong switches you have 69-77 and 78-97. The functionality is the same but the dimensions are different. Also noticed that the 78-97 switches are recessed around the prongs:
https://www.coperacingtrans.com/?product_cat=nag1-parts
The center pin grounds the starter relay when in Park or Neutral.
The two outside pins switch the reverse lights on. Power in (IGN hot) on one pin and power out to the reverse lights on the other pin
Yeah, the switch and insulated plug connector changed in '78. The switch works the same however.
Hoping someone out there can help. I have a non-pushbutton 727 in my 63 Dodge. I had tried the short body 3 prong switch which I now understand to be for a 78 and up trans. I cannot make out a number on my transmission so am not really sure what year the donor car was. This switch did not work either for the neutral safety or the back up lights. I ordered a 68-77 switch (with the longer body) . This works for the neutral safety but still not for the back up lights. I tested the switch and if you push the plastic part all the way in, there is continuity. I added a picture of the rooster comb switch actuator. It seems to have a defined section that should push on the switch but it is not pushing it enough. Is it a poorly made switch? Other thoughts as to why the back up light part does not work?
This may be important to confirm, because if you have a late model (>1978) transmission valve body, you may want to use the later switch. An early model (prior to 1968 back up lamps) may not work, either. A number greater than PK4028XXX could be a late model. Before PK2892XXX may be an early model.
Have you ruled out a potential wiring issue? To test: pull the connector from the switch, and connect/jumper the outer two pins in the connector. If things are working correctly, the backup lamp(s) will go on (with the ignition on)
That said, an EARLY transmission (prior to circa 1968) may not have back up lamps at all, and as such, the rooster comb doesn't work reliably to activate the switch.
Thanks for this. Yes, the wiring is good. I have narrowed it down to the tang on the rooster comb not pushing the white plastic insulator in enough. I bench tested the switch and had to mash it down to get continuity. I am hoping it is just a bad switch and have a replacement coming. If the next one does not fix it, I will give in and rewire using the switch on my shifter as the neutral safety works fine..
next time your under there, look for that PK part number, so you know what you're dealing with.
Hi there,
Definitely wish I had the answer. I assume the number should be on the casing in the picture.
EZ to test switch..
Jumper the outside terminals to turn on reverse lights.
Ground the center terminal to test neutral start function..
Just my $0.02.. :thumbsup:
Yes, it sure should be. It could be an early one. If the number(s) weren't filled in by painting over, then I'm guessing this transmission never had application numbers stamped to it.
My notes on transmission ID numbers suggests the early-early 1962-1964 727 Torqueflites (aka LoadFlite) did not have part numbers stamped on the left side pan rail. If yours is indeed a pre-1965 727, then it may have trouble working the backup switch, since backup lights weren't even a mandated thing (in the US) until 1968 or so.
