- 12:09 PM
- Dec 4, 2009
- Pasadena, Texas
solids lifters junk too?
Guess I need to edit the thread title....what I'm wanting to know is when did 'new' lifters become junk out of the box.......when the ticking is too loud for the exhaust or radio to drown out![]()
Probably longer! Reason I'm asking is I found 4 boxes of new lifters that have been in the cabinet since the late 80's early 90's and wondering if I should throw them on the scrap pile.People been discussing this for 20 years I think
What brand? hyd. or solid? I doubt they are junk. Good inspection of the lobe surface would be in order.Probably longer! Reason I'm asking is I found 4 boxes of new lifters that have been in the cabinet since the late 80's early 90's and wondering if I should throw them on the scrap pile.
I would think those are worth taking a look atProbably longer! Reason I'm asking is I found 4 boxes of new lifters that have been in the cabinet since the late 80's early 90's and wondering if I should throw them on the scrap pile.
Isky solids, number 3102H is on the box and not sure if the box is original to them based on the part #. Wouldn't the 'H' mean hydraulic?What brand? hyd. or solid? I doubt they are junk. Good inspection of the lobe surface would be in order.
No. You can send them to Oregon Cam Grinding will resurfaced them for $5.50/ea if they are used. Better than new.Probably longer! Reason I'm asking is I found 4 boxes of new lifters that have been in the cabinet since the late 80's early 90's and wondering if I should throw them on the scrap pile.
One of the variables is today's oils....imoAND another thing I will say is, there are so many variables involved with cam and lifter failures that even the experts can’t tell you the exact causes.
Powell machine has a lot of good YouTube videos. He will no longer deal with any flat tappet cams. And he used to resurface lifters.
That’s why if its bigger than stock with heavier springs I consider it a wear item.
There are many that can say they installed this cam and those lifters however many years ago and it’s fine. That’s anecdotal evidence and doesn’t take into account all the variables that you may have to deal with.
