How many gaskets do you have between the carb and the intake manifold?I know this is a B-body forum… and I already posted this on the C-body forum 6 years ago in 2019, but I figured I would also post this here to get all of your help thoughts and opinions on this to hopefully finally get this car running right. My stepdad has a 1967 Fury II 2-door sedan with only 400 miles on it and a 440 stroked to 520 cubic inch big block built by the late Nick Wilson of Comp-U-Flow 25 years ago; it has aluminum heads, an aluminum intake, aluminum radiator, electric fans, an Edelbrock 750cfm carburetor, phenolic carburetor spacer, roller cam, TTI headers with a complete exhaust system, an Advance Auto Parts electric fuel pump, electronic ignition by Rick Erenburg, and a slightly higher 10.5 compression ratio. The engine has given my stepdad nothing but trouble and has not run right since he installed it in the car. It would run like a bat out of hell when its cold and do great burnouts, then it would get hot and want to stall. First it started with honing out the cylinders because they were too tight, then it was the carburetor, then it was the coil, then it was the distributor. Nothing but a pain in the a$$. My stepdad went through 3 coils and 3 carburetors, and he says everything is new. It ran great, then it didn’t, then it ran great when we put it away last November, and now it won’t run right again. My stepdad took it out yesterday when it was 98 degrees and it seems like we are back to square one again where it idles lopey like it wants to stall then it does wicked burnouts then it stalls again. I just don’t understand it. It runs, then it doesn’t, then it runs, then it doesn’t. My stepdad is a good mechanic and can work on a regular 440 no problem, BUT he is new to high performance stroker engines. I have been told it could be vapor lock on the C-body forum, I have been told it could be ignition, I have been told it could be fuel.
Here are pictures of the car, the engine, and the post I made on the C-body forum. My stepdad spent GOOD money on this engine and he is so fed up with it he is planning to rip it out and put another engine in the car, and I would like to possibly help him out because I would hate for him to rip it out if it is something small and stupid after spending all of that money.
Any help or opinions would be appreciated!
Thank You In Advance.
67 Fury 440 Engine Problems
I tried to pm you but your in box is full.Not the car no, but the engine if we can’t get it right then yes because he is fed up with it.
Cleared it a bit, PMed youI tried to pm you but your in box is full.
I may be missing something here. I have a 522 stroker in my car. I ran into some problems trying to use a mechanical fuel pump pulling thru an electric that was not running. There are electric pumps that you can pull thru but not all. Use one or the other with a regulator and gauge.The fuel tank is new, and we put gas in it last November. We have not checked the pump pressure, we only have the electric pump on to start the engine after its been sitting and we have a high volume mechanical pump otherwise
The turnpike used to sell it, but unfortunately does not anymore. I know exactly where you are talking about, its only 5 minutes from our house. I will PM you on coming over, that would be greatly appreciated if you are willing to
I do not see the carburetor adapter in there and it comes with that Edelbrock intake manifold.Pictures of the carburetor and spacer for those asking, I remember the carburetor being a 750cfm. Also has an Edelbrock Performer Intake
I disagree.I do not see the carburetor adapter in there and it comes with that Edelbrock intake manifold.
Without the carb adapter you have a vacuum leak.
You can spray in between the spacer and the intake manifold (near the secondaries) to confirm.
I also read the same thing somewhere but when I scrolled down it said it was a AI-generated answer.I disagree.
You don't need a carb adapter with a performer 440 intake and an AFB style square-bore carberutor.
Tho that doesn't mean it's right.... doesn't mean it's wrong either.I also read the same thing somewhere but when I scrolled down it said it was a AI-generated answer.
Hello… honestly no, no real updates. My stepdad has not done anything to the car since I originally made this post, except move it out of the garage a couple of times to move it around. However he says he plans to work on the car soon, and he plans to put a tamer cam in it as his last attempt to keep the engine. He talked with his high performance car mechanic friend Bill Atwood (for those of you in New England have likely heard of) who works on these types of things, and he says its likely normal and that its “the nature of the beast”.month later updates?
