Coelacanth
- 5:20 AM
- May 10, 2024
- Edmonton, Alberta, Canada
I've been researching this issue and I've come across conflicting info. Do the 1970 Charger sidemarkers flash when signalling left/right? My sidemarkers are all working when park lights or headlights are on, but don't blink, no matter what I've tried.
Background: I installed all LED bulbs in my instrument panel, including the L/R turn signal indicators. I also have LEDs installed in my hood.
With the good old-school 552 flasher cans installed, my 4-way flasher works and my park lights & taillights work, and will also signal L/R, per usual.
However, nothing I've tried will get the sidemarkers to blink. I have tried 3 different supposedly LED-compatible flasher units and none of them work; I've read that you need these if you have LEDs installed but my only LEDs are in the dash & hood indicators, and when I tried any of these LED flashers, NOTHING flashes; not the markers, nor the park/taillights. Hence, I put the old 552 cans back in.
What I've researched is it appears since the sidemarkers ground to the body differently than the park/taillights, the wiring isn't there to have them blink, and a separate single wire must be run to each sidemarker from the park/taillights, which actually makes sense. I don't plan on putting LEDs in my sidemarkers, park or taillights, just for the record.
Any ideas why my sidemarkers won't blink, or is that perhaps the way it is without the wiring mod I read about?
