That Summit Racing 6 qt B-body (& E body IIRC) Hemi/B/RB oil pan
you can get either a 3/8" or a 1/2" pick up for it,
it's for all the above BB Hemi & Wedges & can be used on all the above
not sure the same number as listed above, but should work
may want to check your drag link see if it will clear too
you may want to check for connecting rod/bolt clearance for the windage tray too
may have to go to a deeper windage tray
they make one, windage tray in composite at Summit
with formed gaskets on it already
at
Mancini Racing Mopar Performance Parts - Yahoo Top Service Award Winner!
they also sell the same dimension Street Hemi 6 qt oil pan
& corresponding pickup B body (E too)
IIRC the 6 qt pan (being sold by most all them mentioned)
is about it's close to 1/2" deeper, off the pain rails
5" for the std wedge 5 qt pan vs 5-1/2" deep 6 qt pan IIRC, but don't quote me)
then the std #402 383/400/440 oil pan is, you would have to modify yours
or
buy a different pick up, for that pan (in both 3/8" or 1/2" pick ups)
&/or if you are running a girdle you will need a lil' long pick up too
good luck
MRE Mancini Racing 6 qt Mopar BB/B/RB pan
Below
old shot of dimensions from sump front & rear top 65/361
middle #187 68 Fury
(both top 2 below are irrelevant to what we are talking)
bottom modified/repaired #402 for a 69 Charger
