Flex plate crank bolt craziness?
Chad Hilburn
2:50 PM
Hey, guys, I'm running into a weird situation. Most of the flex plate bolts that bolt, the flex plate to the crank on a mopar big block are supposed to be 7/16 thread. I've got a 383 that is a early 68 engine. It may even have a 67 casting date. But i'm telling you, the seven sixteenths bolt won't fit into the crank holes. There's got to be a smaller size? Anyone run into this?
Have you got the right thread? 7/16-20? (I do not mean to insult, just asking. You seem to have an unusual problem.)
Are you sure you don't have Metric bolts? Or 1/2 inch.?
There has to be a reason.
Never. Doesn't mean it never happened though. Run a tap through it?
Hey there, no, they are actually smaller. Ran a fine thread 3/8 thru there and fits perfect. This is the second time I ran into this. Just recently we got a 7/16-20 set of arp bolts for his, and same thing. Too big. Had to go to next size down
I'll tell you what it literally is a smaller bolt, all six of them. I got what I think is a 3/8 fine thread holes
