Frontend ride height, limitations
Moparfiend
2:46 AM
HOT
Disregarding exact front end geometry like camber and caster, what are the limitations on front end lowest ride height?
For example, bumper clearance and steering geometry issues?
I guess what I’m asking is how low can I make the front end before I have clearance or steering issues? And how do you tell?
I had mine too low for a bit - don't know the measurement but I could feel it hitting the bump stops in the steering, particularly when I would go on/off bridge transitions on the highway at speed. Car didn't feel stable for a moment.
Ended up putting in new torsion bars and springs - 1.03 bars and +1" springs to give it a slight rake front-to-back . Set the front end to spec and it drives much better now. It did raise the overall ride height of the car which is not what you’re after but mine was too low before and would drag the exhaust going over sharp angle changes like going in/out of the Daytona race track for car shows.
after the changes
Torsion bar rates and shocks will matter more as your ride height gets set lower. With less suspension travel, you have less room to move before you bottom out.
I am below stock height but I like my cars that way. These Mopars can get better alignment numbers the lower the front end sits.
Is this thinking correct? The lower the ride height, the lower, the torsion bar rate and the more rough the ride?
@kerndog will be along on this.
Too low and it hits the bump stops. That's bad in many ways and can cause loss of control in some situations. Suspension needs to work, move and control the car.
I need to read the section on suspension in the FSM BUT practical experience is also helpful. Thank you.
The FSM will not really answer your question, but I advise reading it anyway. Lots of info in there if we pay attention.
The spring rate does not change with height
So what is happening as the LCA ride height bolt is adjusted to increase ride height? Isn’t it using more torsion spring force on the front end?
What is happening is the vehicle sits higher.
The weight doesn't change, the spring rate doesn't change.
I set mine where the gap between the LCA bumpstop and the frame rail is about 3/4". That's still plenty of suspension travel and the front end sits level. I don't like the look of the front end being higher than the rear, even if that was the "factory" look.
I've got the 1.03 torsion bars and Koni shocks and it all seems to work well.
The factory rake was level, and ironically at the factory ride height is exactly where the best performance of the stock steering/ suspension was engineered.
1.03 torsion bar
That's a heavy bar over a stock figure. I think a Hemi bar was in the .890 range but not certain.
Also places like Energy Suspension have a pancake bump stop that may be only 1/2'' compared to the factory bump stop.
I won them in the P-S-T Superbowl competition on here a few years back. No real change to ride comfort but improves the handling for sure.
If a modern car of today rode as soft as a 1970 Valiant, the road test critic would bash the car for having a marshmallow ride and slow steering response. During their time, our cars were ahead of the class. Built back to stock form, they handle fine but are behind what modern cars feel like.
There is room for improvement.
Moparfiend and others, are your bars the originals? Bars, springs and many other items don't last forever. They lose their strength over time and can't perform. Case in point, look in your mirror. Are you as strong and resilient as you used to be? I know I'm not. If you want to drop the front end down, as Kerndog and others like me have done/do, put bigger bars in. This will change the rates and help to stop, or slow down, bottoming out on suspension travel. I just recently put some 1.06" bars in my 67 wagon, had .880's in it that were the original 67 units for a smallblock, which it had when new. The suspension was worn and tired. It's a night and day difference now. Car rides great with no bottoming out.
My bump stops...
I have 1.15" torsion bars and Bilstein shocks. The car rides firm but not harsh. The bump stops sit about 5/8" to 3/4" from the frame, the suspension can theoretically move UP 1-1/2" to 1-3/4".
One comment about the adjustment of the torsion bar screw and spring rate....
I understand the belief that the spring rate is unchanged but I have noticed that as I have adjusted the T-bars to get the front way UP, the car does feel much more springy. I've done this to A body cars, cranking the t-bar screw way in to get the front up touching the upper bump stops.
In reality, you're just moving the adjuster finger/blade down more, putting more leverage on the torsion bar but it sure seems to make the car ride firmer.
RemCharger is correct. Spring rate does not change. If you lower the car, your suspension is going to bottom out on the bump stops more often. You can reduce this, but not eliminate it, by using thicker t/bars. Another thing to consider: the length of the LCA is longer than the length of the UCA [ through the pivot points ]. That means the b/joints swing through different arcs; it might be difficult to get good wheel alignment with the available adjustment of the UCA
The lower the car is, the better caster you can get. Read the chart below....Caster is very desirable for stability.
The old fashioned original alignment specs are terrible. Some had positive camber and either negative caster, zero or very slight positive caster.
With a car with A body steering knuckles/spindles, at standard ride height, this test subject was set to zero camber, 1.17 degrees of positive caster and .059 total toe in. Now move UP for dive.... (suspension compressing) The caster increases a LOT. At 2 1/4" of dive, the caster goes to 4.892 degrees. These suspensions gain caster and negative camber as the suspension is lowered.
You can get these cars to hold the road so much better with a good alignment by a guy that knows what he is doing.
