BruteForce1.
Found a 426 Hemi Engine trying to see if I can find out what vehicle it came out of casting #2468330
Need more info than that. Casting date, stampings, possible VIN.Found a 426 Hemi Engine trying to see if I can find out what vehicle it came out of casting #2468330
Day 2700 is Wednesday, December 18, 1968, So if it was a production line install it would be for a 1969 car. Any numbers on the pan rail or the bell area by the oil sender?Here are the numbers found on the block, can someone decode this so I l know what car it came out of, Thanks
Its for sure a 69 production block by the big E stamped under the bottom, and the 10,000 day calendar date. some early 69 blocks had the complete vin stamped on the machined pad found on the passenger side of the block above the oil pan, while others had the last 8 digits of the vin stamped. It should have that unless its been removed or modified. Please look in that area, and let us know back.No only numbers were what I uploaded
I believe no one mentioned this, but a '69 engine with no VIN stamp could be a warranty replacement engine.
My '69 HEMI has the partial VIN on the pan rail. Hamtramck Charger. I also have a '68 Hemi 4spd. with a partial VIN as well, again, from a Hamtramck car.
