What's the REAL Compression Ratio for Stock 69 440 HP??
The factory warranty program may have paid for the r&d but the problem is the same for any open chamber mopar
remember I'm talking street not race only builds with a narrow high rpm power band
need a wider power band then still works to add some lower end of the power band torque
Deeply interesting information here! So who sells these pistons that enhance quench with open (906) heads? For a 383?
I built a 440 for a friend. He wanted it near stock with a very smooth idle. Used quench dome pistons. Equalized the depths of all the open area of the chamber. set it at .040" quench. Did the bowls and put 30 degree intake seats in them. Used a small 214@ .050" cam. Stock intake, carb, air cleaner and exhaust manifolds. True 9.7-1. it rattles a bit on 93 octane in the summer at full 36 degree timing setting. Other than that it runs really nice. Should have made it 9.5-1
That’s good info Doug. Do you recall what the cranking cylinder pressure was.
The one engine that I am familiar with is very similar to the one you described in the same mid-west type elevation, but with a 220-ish cam. On the edge at 9.5:1, and blew about 160 psi, IIRC.
The 440 in my r/t would blow close to 180psi with kb184 pistons and the 272/.455 cam; 9.4:1 compression. Of course different test gauges may give different results.
