73/74 Roadrunner Lower Control Arms
I’m having problems locating bushings and pivot pins. Will 68-72 B Body LCA’s work? There are plenty of parts and options available for those. Do I have any other options such as a control arm from an A body or something like that? There seems to be no stock or aftermarket parts for 73/74 LCAs.
We still need to knw exactly what you are working on.
I found the 12316 TRW on EBay NOS. There were 8 of them. Being NOS I am worried about the shelf life and rubber so I bought all 8 to pick the best ones. I hope those are the right ones. They look correct but we haven’t taken the old ones apart yet. The pivot shaft is pressed into the bushings and then that assembly is pressed into the LCA. If those aren’t the correct ones I need to figure out what are. Worst case I got $80 of LCA bushings I can’t use.
74 Roadrunner
73 and 74 use the TRW # 12316 I posted above. The earlier years use a different number. Probably the same design but a different size/dimension.
70-72 and 73-74 do take a different bushing in the Satellite/ Road Runner models.
74 Parts manual shows two possibilities.
Okay. That’s what I found NOS. Let’s hope 2 out of the 8 I bought are useable. Is there any way to soak them in something to recondition the rubber if it is dried out?
No.
They'll probably be fine as long as they haven't been exposed to ozone, UV, or high temps for a long time.
Just remember they might be different. I posted the mopar numbers and your car has two possibilities.
Regarding the lower control arms on a 1974 Road Runner, the lower control arms interchange with all 1974 - 1979 B-bodies, 1979 - 1981 R-bodies, and very late build 1973 B-bodies with press-in ball joints. Other 1973 B-body control arms with screw-in ball joints interchange with the change to 1973 ball joints. 1972 and prior B-body control arms and components are different and do not interchange. The lower ball joint numbers from older companies are as follows:
- TRW 10285 (10163N 1973 screw-in)
- Moog K7069 (K719 1973 screw-in)
- Sealed Power 801-10285 (801-10171 1973 screw-in)
- Spicer or Raybestos 505-1028 (505-1001 1973 screw-in)
- McQuay-Norris FA952 (FA958 1973 screw-in)
Other more modern sources, such as Pro-Forged or Mevotech, may have other offerings.
The lower control arm bushings for 1973 - 1979 B-body and 1979 - 1981 R-bodies interchange. Note that the shown listing for different bushings depending on whether rear isolators (Iso-Clamp) are used is a difference in durability and stiffness. The bushing for non-rear isolators is higher durometer rubber for heavy duty applications such as police. The bushings physically interchange and the different bushing use was later dropped. The aftermarket only produced one replacement. As indicated, TRW bushings are part number 12316. Some old brand numbers are as follows:
- TRW 12316
- Moog K7059
- Sealed Power 813-3
- Spicer or Raybestos 565-1028
- McQuay-Norris FB360
Other more modern sources, such as Pro-Forged or Mevotech, may have other offerings here too.
The lower control arm shaft, or pivot, is interchangeable with 1973 - 1979 B-body and 1979 - 1981 R-bodies. The shaft was originally only serviced with the control arm assembly by Chrysler until 1977 when the shaft and bushing package, part number, 3837079, was made available. The older aftermarket companies did not produce a replacement shaft, but it may be available from some modern suppliers.
- TRW 12316
- Moog K7059
Thank you. This is good information.
I was able to find one of these NOS online using that part number. AI and I can’t find another one. Just need one more.
AMS Osolete part number search for 3837079 shows they have at least one in stock.
You can send them an email, but follow up in the morning by telephone.
Can anyone snap a photo of the diagram in the FSM for how the bushings and pivot pins go together? I’m getting conflicting information on how this goes together. A web search only turns up models up to 1972. 1973 and 1974 are different. My FSM is with the shop an hour away.
