six pack tuning help in NJ
Strato58
2:53 PM
New Jersey
Lookin for someone who can tune my car properly. Getting lots of bog. I am not a mechanic and have no chance doing this. Looking for someone with lots of six pack experience. Im in central jersey and will travel some for the right person.
Can you tell us what you have? Stock carbs or Promax modified? Are you able to take them apart yourself? I just went through this myself. Your gonna have alot to do in an afternoon, hopefully that person has all of the separate parts and gaskets that you will need.
Im in Central NJ, Woodbridge. The carbs are stock. Unfortunately Im just not a very mechanical person The car runs fine, starts fine just bogs under hard pedal. Ive owned the car a short period of time and it has not had very much use in years.
if you feather the throttle back during the bog does it straighten out?
Yes it does it will open all carbs and work. Its just the initial bog and you can't stay in the pedal.
There was a mechanic here in Long Valley that favored Mopars, he moved his shop a couple of years ago and I don't know where. Long Valley Auto Body (also favors Mopars) would use him, their number is 908-876-5584. The mechanics name is John they would probably know where he moved to. Everyone would bring their classic cars to him because he understood carburetors.
When the car has not had much use in years then it just needs a little carb cleaner, just spray the throttle shaft on the front carb and rear carb to see if that helps.
I would go with the tall yellow springs in the outboards. To adjust them properly, should have Promax base throttle plates in the outboards. It's probably got a 6.5 power valve in the center carb. Would go to a higher number with that, thinking 10.5 on that. I tried for so long to get rid of the bog that I induced, and kept trying in the wrong way. There are several little things here that I am skipping, but those 2 should things, I would bet will stop his bog.
Having said what worked for me, doesn't mean that it will work for you. Difficult to arm chair quarterback somethings.
If you have stock 31 squirters (accelerator pump discharge nozzles) you can go up a few sizes. I used 35's, easy to swap on the center carburetor although you will need to remove it to do it without potentially dropping a screw down the intake. I just stuck a rag in the carb in case. This is to cure a lean condition when floored.
Turns out I have a bad distributor so its not holding advance. Going to take care of that 1st and see where the carbs sit after that.
Do you know of a shop that has a Sun Distributor machine? Some of the best money I ever spent. The best that car ever ran
I have a few here all I do is Mopar distributors if needed.
I don't know of any in this state at all.
If you need help with Mopar repair you can see Jimmy Vignona in dutchess county NY. He helped me with my distributors when I was working up in north jersey. He should still be running his shop in Wappingers Falls. There is also John Rogers from long valley service in long valley NJ. He closed his auto repair shop (retired) but last time I talked with him he was still doing Mopar work on the side. He knows these cars very well and has an FC7 car himself. He is on LinkedIn you can reach out that way.
