Console Neutral safety switch.
chrger1967
3:20 PM
I'm looking to install a console in place of the buddy seat. I am repairing the wiring harness for the console. Only thing it, where does the neutral safety switch come into play in the console? The harness I have has the backup light switch, but I just don't see anything for the neutral safety. The wiring diagram only mentions the neutral safety on the starter relay and nothing else after that. Thanks, guy.
Pictures for reference if you need:
A picture for reference if you need:
Awesome, Thank You. Is it a common thing for one of the leads for what I think is a console light to be burned out? The wire from the shift indicator light is fried. I’m going to repair it and use this harness, but prevent add a fuse to this lead.
Welcome. I switched all my bulbs to LED since the original bulbs can get rather hot and burn the plastic lens. If you need any parts PM me, I might be able to help with a source. I added a C body rear bezel on my console with the lighter and light.
Yes, I plan on doing the same thing. It makes a big difference with the lighting in the car as well.
This is the bulb I used and don't forget a breaker for the rear console lighter. The originals look like this FYI.
