- 9:52 PM
- Aug 24, 2015
- West Palm Beach, FL
I bought a new pair of 440 Source Stealth aluminum heads for my 383 build - 9.5:1 street build with HUG SEH1620BL-12 flat tappet hydraulic cam (specs below). Based on things I have read in this forum and elsewhere, I sent the heads to the machine shop to be checked and they reported that some of the seats were not installed correctly. Supposedly they corrected the seats and blended the chambers, performed a valve job then set the valve stem heights and spring heights to "Competition Specs", whatever that means. 440 Source specs their springs at 1.875" installed height - I wish that I had checked these before they went to the machine shop. I bought the Hughes springs (HUG 1106H) that are recommended for the cam which call for 1.880" installed height. That seemed close enough to the 440 Source spec that I didn't think I'd have to make any adjustments but thought I'd check anyway.
I measured anywhere from 1.825" to 1.844" using a Proform valve spring height micrometer. I verified the measurements more than once, especially for the min and max outliers, and the differences are far larger than my measurement error. First, the variation from valve to valve bothers me, but perhaps more importantly won't the shorter than spec installed heights lead to higher spring loads?
I started down the path of using +0.100 retainers from Hughes along with the appropriate shims to bring the spring heights into spec. However, the machine shop installed metal clad viton valve stem seals which do not appear to be easy to remove and reinstall and the shims won't fit over them. Am I overthinking this or should I try to get the machine shop correct them?
If I can't get the machine shop to step up or do the work on a timely basis, can the valve seals be removed and reused? If so, how? Also, are there any issues with using multiple shims? The shims come in .015, .020, .030 and .050. I mapped out the combinations of shims needed bring each valve into spec and some valves need as many as 3.
Thanks in advance for any guidance from the experts.
