Loose horn ring on ‘65
BigFlo
11:37 AM
NJ
A minor annoying issue - my horn ring rattles when driving. Otherwise, everything works fine. I’ve tried playing with the metal tines on the rear of the horn ring that slide on the ramps when you twist the horn ring on. That hasn’t helped. Any ideas out there to tighten the horn ring?
No. The mount to the chrome ring is solid. There is good resistance when I turn the chrome ring to mount it to the base (whatever that piece is called). But after it’s mounted, it has some play in it. Not sure if that’s normal, but it has enough play to rattle when I ride over bumps in the road.
Just guessing here. Try bending the tabs down then twist them to ride up the locking ramp.
Mine is real tight. The issue I had was getting the re-pop wheel to fit.
Ok. I’ve tried a version of of that but I will try again a little more aggressively.
It’s the same - a 65 Plymouth. I didn’t have mine removed the other day so I found an image online.
But I just removed it - photo attached
Better description: the play in the chrome ring is both rotational and in the direction of honking the horn. It’s been this way since I drove it in the mid 80’s. Rotationally, I can move it ~1/4” (measured at the outermost point of the chrome ring). In the ‘honking’ direction, the bottom of the chrome ring has 1/8” play. The parts in the column (horn button, attachment screws and plastic spacers) are in good shape and tight. Maybe I’m expecting too much but I’m trying to be rattle-free!
