Exhaust manifold question, and Happy Thanksgiving wishes…
Plyrr471
12:15 PM
LI, NY
Hey guys, first of all Happy Thanksgiving to you and your families, hope you enjoy the day. Attached is a pic of my ‘71 RR exhaust manifolds which I’m currently restoring in prep of replacing the headers currently on the car. Top piece is as it was since it’s been sitting for the last 40+ yrs since I’ve owned the car. Bottom piece has been worked over with a wire wheel on a drill. Do I need to continue to brush the one I’ve started or is it prepped sufficiently for hi temp paint, like Eastwoods? Should I apply some Naval Jelly maybe?
Can you guys recommend a source for a gasket and oem, or similar, bolt, sleeve nut, stud and bolt kit kit? I see kits on ebay, but am curious as to what you guys are using. Thanks all, have a great day.
Those look great. I’m without blasting cabinet, but I can run a gun as I have a compressor. I’m afraid to bake them in my kitchen over or on the gas grill as I use them to cook. I imagine curing them in the oven would foul it, no?
From the factory, there are no gaskets between the head and manifold. I have great success using a little high-temperature silicone on a "straight" manifold.
Good am Don, I may just pick up a crap little sand blast gun from Harbor Freight and shoot them in the yard so I don’t have to worry about a cabinet. I’ve got a compressor so I’ve got that covered.
Honestly I don’t think its worth all the trouble to blast and prime them. Use your wire wheel to knock the flakey rust off and spray them with hi-temp. They will never be perfect after you start the engine the first time anyway.
68-500, I get that but would hate to have to freshen them up in a few yrs.
The wire brush doesn’t get into the pitted areas but blasting does. I can still see rust in the pits in your picture, so that’s what you would be painting over. If you’re going to spend the time, blast them.
I soaked mine in molasses solution, pressure washed, painted with hi temp and cured in kitchen oven. They look great after 4000 miles.
Another option is Slip Plate- there are reviews on here about it-
