Virg464
Well, that took a lot longer than it should have, time to start laying out on metal. The worst part, the roll cage is installed and I had to crawl under the cross bar to get into the back seat area, serious PITA!
Bring your tools to Peoria next weekend and get after it ha ha ha
It looks great! Nice work!Well, that took a lot longer than it should have, time to start laying out on metal. The worst part, the roll cage is installed and I had to crawl under the cross bar to get into the back seat area, serious PITA!
Of course lolSounds great. Can I buy the materials too?![]()
Yes, I know the feeling not an easy task.Well, that took a lot longer than it should have, time to start laying out on metal. The worst part, the roll cage is installed and I had to crawl under the cross bar to get into the back seat area, serious PITA!
I always found it easier to go over the crossbar..... but watch your head on the rear bars!.Well, that took a lot longer than it should have, time to start laying out on metal. The worst part, the roll cage is installed and I had to crawl under the cross bar to get into the back seat area, serious PITA!
Thought about that, but with my 64 yr old luck I'd slip and rack my berries on the bar!I always found it easier to go over the crossbar..... but watch your head on the rear bars!.
(And it was over twenty years ago!)
None of my bars go through the rear divider or seat back area.OK, cutting metal and wondering how you guys navigated this issue. The place where the roll cage bar passes through the divider, the spot that I didn't cut yet. Did you make a cut along a (see dotted) line to allow the piece to be opened up and pass over the bar? If so, how did you treat the cut line after the panel was in place? Or, is there another way that I'm not seeing? The dotted line in the pic would be from the P/S wheel well to the bar.
Had I been a little smarter, I would have gone this route as well. My back bars are so close to the wheel tubs that I just made a weld in piece to permanently cover that area and my center panel will go between them.None of my bars go through the rear divider or seat back area.
Fortunately my car wont' be going at mach speed, how the heck do get inside that thing?! That is some awesome work though.None of my bars go through the rear divider or seat back area.
Pretty sure .040 is the NHRA Rule but I’d have to double check. I used .040 and then seam sealant. Funny enough, about to remake mine after I put a cage in.Tried to find a thread on this but wasn't successful. Wondering how you guys install the sheet metal divider where the rear seat use to be (dedicated 1/4 mile car). Mainly looking at the wheel well area (I have a soap stone line on plane with the cross brace) and the floor pan area, the cross bracing and the package tray area are pretty straight forward. Do you install (screw/rivet/spot weld) brackets in place to attach the sheet metal to? Is it possible that someone offers cut to fit kits, or something like that?
Borrowed it from a buddy of mine.Where did you get that laser unit? Pretty neat.
What brand is it? Model number?Borrowed it from a buddy of mine.
I built the divider and holesaw'ed holes for the rear down bars before i welded em in.OK, cutting metal and wondering how you guys navigated this issue. The place where the roll cage bar passes through the divider, the spot that I didn't cut yet. Did you make a cut along a (see dotted) line to allow the piece to be opened up and pass over the bar? If so, how did you treat the cut line after the panel was in place? Or, is there another way that I'm not seeing? The dotted line in the pic would be from the P/S wheel well to the bar.
I have a bead roller and found out pretty quick that it needs some practice lol....and nowadays, don't need it.Bead roller is 100% the way to go in my opinion. If you send me the stuff I would do it for you but probably not the most convenient thing to ship.
