Rear tire size
Splangj
12:13 PM
California
Hello all. Does anyone know if a decent 275 50 15 radial tire exists? I was running that size in a MT drag radial, but I’m not racing anymore, and it was “sketchy” in the wet. I’ve found plenty of 60 series, but I like the handling and look of the 50 much more. Thanks in advance!
That’s exactly what I had. They handle very well too. But I’ve been caught in the wet before, almost looped the car at 30mph, that’s why I’m looking for same size regular radial
Yowzers! Note to self :)
All the 275 50 15s I found were some form of drag radial, Hoosier, Mickey or Nitto.
Hankook does make a 265 50 15 street tire (kinergy). Theoretically 3/8" narrower section. So does Gripmax. Gripmax look exactly like t/a tread.
IF you have the room, lots of 295 50 15 street tires.
The Nitto looks a bit more street worthy than the MT for certain. And thanks 33 IMP, the gripmax 265 50 looks pretty good, almost an exact copy of a TA. I guess 3/8” really isn’t much less width. I just put 295 50s on it a while back, but haven’t tried it yet. I’m fairly certain that it’s going to rub though
not sure why you think those will rub... You have miles of space there..
This is mine and hasn't rubbed at all..
It’s a 69 rr. The reason I’m worried is because when I removed the MT 275 50s, I noticed tire rub marks on the inside of the wheel well. I’m assuming the leafs must flex some.
Maybe just me, but I always seem to have clearance issues to the inner wheel wells before they rub on the leaf springs. A rear sway bar makes a big difference with that issue.
So no leaf flex, but the leaning of the car huh? My car is very stiff. Mopar HD biased springs, KYB shocks and a 3/4 sway bar, so it doesn’t lean much. Maybe the rub marks are from me driving fast with 4 people. I’m gonna drive it soon solo and see if it rubs.
Agree. It's likely not rubbing the spring. My slicks are within 3/8" to the spring, and don't rub. But my car doesn't handle for ship, so it's not likely to rub on the inner fender either.
