Lowest new gas prices in your area?
Apparently SC PA didn’t get the memo yet. $3.19 for 87. Why is diesel still over $4/ gal?
I drive 5 minutes to the next town between where I live and work and get it for $2.94-$2.99 for 87. It was $3.39 for weeks while that town was at $3.04. Diesel went from $3.69 to $3.99-$4.19...
I pass seven stations on my daily commute.
I usually have time, the same day, after a high volume station "gets it's truck" and prices go up...
...to get to a low volume station before they get their truck.
I filled the Challenger with 91 octane, premium, non ethanol gas yesterday at OnCue, which sells Phillips 66 fuel, for $3.14 per gallon.
Jeez. I paid $3.60 for 91 10% a couple days ago, and that was the best price I found, and with a supermarket user discount.
IF ethanol free was available out of the pump here (available,but only in small cans for gardening equipment) I'm sure it would be $5
In california, IF it was legal (it isnt) I'm sure it would be $7-8/gallon.
Down the street and across the river, california cat-pee 91 10% is $6.50
Yesterday, walmart here was $3.05 for 87, $3.35 for diesel.
New 7-11 is advertising "Rec-90".
Don't know how much, though.
The cheap gas will "work" in a modern fuel injected car but leaves deposits vs the gas from top tier stations which have better additives.
I see about $2.65- 2.70... ( MUCH LOWER THAN A FEW YEARS AGO ). By the way, based on inflation, the adjusted cost for gasoline compared to the late 60's/early 70's is way over $3/gal.
Even here in IL gas prices at some stations are cheapest I’ve seen in years. Shocking disparity though, I’ve seen everything from $2.77 to $3.69 for regular at various area stations.
Figures, I’m not doing much driving now! I drove my Scat Pack for the last time in 2025 the day after Thanksgiving. My truck is buried in snow and I avoid driving it when the streets are salted. Gas will probably be $4.50 when spring finally arrives and I’m driving the gas hogs again!
I envy your Ram, and Scat Pack..... just not your weather.
It's the same here. No non ethanol except lawn equipment because of bad air pollution in ATL. I think 91 10% is about 3.50 here now. I burn 89 in my 11 challenger, it's about 3.00 now.
I run 91 for around town, cause I tend to use some power, now and then. For trips to california on the cruise control at 3 or 4 above the limit, I top off with 87. Same for a trip from CA to AZ, except it costs a bunch more......
Top Tier Gas station finder.
I run Costco in the gasoline cars when I'm in california, it's cheap and "top tier". But they don't sell diesel, at least nor at my local ones. Sam's for diesel. Filling the pickup or box is a much bigger hit than the cars, even the ones that have to use 91 (or more...... avgas, lol)
We get fuel points from the Ingles grocery stores, and they have quadruple points on Fridays so that's when we shop. I use the points to buy diesel for my truck at their gas station so I can usually get it for around 2.50. 20 gal limit. Helps a lot.
