Road Grabber
- 4:49 PM
- Apr 14, 2020
- Sarasota Florida/NY State
My current cam has 48 degrees overlap and runs about the same or a bit better than the previous cam with 54 degrees overlap.
Andy F. made 550 hp with that cam with manifolds on his 470. Pretty small cam. Probably 0.500” net lift. Probably 230 -232 degrees duration at 0.050” when considering the 0.028” lash.
View attachment 1968850View attachment 1968854View attachment 1968855
500 cu. In.
600 hp -ish
Manifolds
15” idle vacuum
Used a stock stall converter for years
3.23 gear
2 1/2” exhaust
15 years old
Drive it to work. Drove it to both Carlisle and Mopar Nats this year, with track time at both.
Probably not a 50,000 mile motor. With a couple changes, could be. But ask yourself this how: many miles do you really drive your car? You’ve had your car for 30 years. How many miles did you put on it? What does your next 30 years of driving look like?
All that said, based on your comments in this discussion, keep the cam, put headers on it, put it in the car, close the hood and forget about it. It won’t matter if I it makes 450 or 550 hp. You, nor anyone else will know.
If you want to stick with manifolds an explore a better cam, contact someone that has experience and does it for a living. Like PRH
Who is PRH?
The lack of much difference installing the more efficient heads and bigger cam was the reason for inquiring and higher expectations.
Time will tell after the new dyno runs without bent pushrods.
Thanks for replies.
