PRHeads
- 10:56 AM
- Aug 31, 2018
- So. Burlington Vt
Any updates on this one?
Still going with?
6bbl
Ex manifolds
1.6 rockers
I assume a trickflow top end cam kit is the same cam we are running in the video below? The TF cam is not an exhaust manifold cam, it needs headers.
This video is a 11.3SCR 91 octane pump gas 440 with stock E street heads and (Howard’s) trick flow 243/247 108 LSA cam with solid roller lifters (Comp endurex’s) and 1.6 rockers arms .640/.640 lift. The ICL is 106*, or -2 from how it is ground. The lash is set to zero cold. We drive it all over. We are shifting at 7000 now, video was 6700. It really goes after it hits 6000. TF240s would probably be shifting just over 7000, would be wicked for sure.
We’ve never had a vacuum guage on that engine. I doubt power brakes would work very well with a 440 on pump gas. If it was a bigger stroker it would likely work. For power brakes the LSA needs to be spread out wider with less overlap. We often do custom cams.
It has mechanical roller lifters. There is only one trick flow cam that I know of for a BB, and it is ground by Howard’s, 296/300 duration is at .006” tappet. 243/247 is at .050”
It has 1 7/8” Hooker header with a full 3” exhaust, X pipe with full tailpipes, long bodied dynomax turbo style mufflers. Ported weiand Team G single plane and a worked over 850 Holley. It was in full street trim.
Agreed, I think Andy F. also found that the MP .520 solid cam was about the best out there with iron ex manifolds. Overlap is your enemy in that application and going bigger tends to work against you. Dwayne spec’ed me a cam with 113 LSA and about .550 lift for my manifold motor.Andy F did a bunch of tests that liked the wider LCA with manifolds. I believe if you ask Dwayne about pure stocks he will agree.
Doug
