TTI vs. Dougs headers
Those particular tti's fit very well in my brothers 67 383 4spd. The ttis are all designed for a certain application.
The Doug's are a one size fits all . And some of the comments are coming from guys with RB experience.
I assume you mean the insulators, or do you find the metal brackets vary sometimes?
In any case, I appreciate you mentioning it and I'll check both. I got a couple pairs of brackets laying around from various mopar big blocks...
If the rubber is not up to snuff, the engine will sit lower and clearance will suffer.
Yup...
Mostly the insulators..
Mopar motor mount issues often appear as excessive vibration, clunking noises (especially when shifting or accelerating), rough starts, or a jerking sensation, stemming from worn rubber, cracks, or complete failure, leading to engine movement, header clearance issues and potential damage to other components; common solutions involve upgrading to stiffer aftermarket mounts (like Deyeme) to better handle torque.
Here is a link to Deyeme.
https://www.deyemeracing.com
Just my $0.02... :thumbsup:
RemCharger, when you say those particular TTI's I assume you mean the TTI 383440-134 that I mentioned at the start of this post. Does your brother's car have power steering?
Based on the comments I'm getting from all responses, I do get the feeling that BOTH choices will be good.
Today I'm leaning toward the TTI's 383440-134 because
1. My big-block building days are far from over, and this particular header will fit both. When I build the next RB, I can reuse the headers but will need a mini-starter.
2. The TTI's appear much more precisely manufactured from what I've seen. I ran a set in one of my earlier '67 R/T's and had no problems with fitment. That car was a 4-speed but manual steering.
3. Very proud to buy/support American. Mexico OK, but still feel better about parts made in USA. I can go on about the subject but won't.
4. Originally attracted to the Doug's because I thought the stainless was a good idea. Thought a little more and decided to nix the stainless.
5. I know that TTI does a good job packing their headers. I've read comments (not this site) about Doug's headers arriving damaged. What a pain in the *** would be to deal with. If I scrape or dent or drop something from the bench OK, I can own it. But if I pay big dollars to get something that's beat-up before I open the box, I'm not happy.
Thank you to all for your comments.
There's no difference in applications between Doug's and TTIs. Dougs are not one size fits all. B Blocks are listed separately from RB Blocks, that's it, with both companies. Doug's is just a little easier on the wallet. They have increased the price quite a bit lately though.
Thanks, I haven't seen the listing for the low deck Doug's that I recall. Just the 7 B series TTIs and the 10 RB versions.
The skinny 1 3/4's are listed for both applications.. which proves how well they fit.
Yup...
I looked at this with some intrigue, but they want you to send in a good set of mounts to be molded. Unless they happen to have a set already mocked up when you inquire?
I ordered some 440 source mounts last year. Have yet to install. Those got a lot of good comments versus the crap most people sell.
I had TTIs and changed them out for Dougs due to the better sparkplug clearance and less interference with the torsion bars and starter. With the TTIs I had to fab 1/4" thick spacers for the motor mounts in order to raise the headers above the pitman arm. Brand new mounts and flat zerk fittings. Both headers are excellent products. 3/8" flanges, heavy wall tubing and good finishing. You make your choice, but be aware that headers are known to need a little massaging for some car models. Just a part of "hot rodding"..
BTW, I recently changed out the Dougs for the Schumaker Creative Services Tri-Y headers. Great starter servicing, excellent spark plug clearance and no "adjustments" to the tubes. Lost some horsepower; gained some serviceability. At the point the tires break loose on the street the extra horsepower isn't missed...
I have 2.5 inch pipes and Dynomax muffers on street 440/727 Coronet with Power Steering.
Seems like the Doug Thorley are overkill.
How did you measure for the collector flange to engage the rear of the Tri-Y headers? Wondering if I can use the flanges I already have. Thanks
