Source for Gas Tank Sender
Joel Talka
8:22 PM
Ocean Breeze Florida
Quick question... My 1966 Coronet developed a small gas drip where the filler neck goes into the tank. I'm going to drain the tank and do the repair. While I am at it, I would like to replace the sending unit in the tank. It is a re-pop unit I picked up when I replaced the tank. It has never worked right, reads 3/4 when the tank is full. The question is where should I go to get a replacement sender that is accurate? Thanks, Joel
Only accurate sending unit that I know of is a very expensive original, IF you can find one. IMO all aftermarket units are not accurate.
Thanks for all the input, much appreciated! I will be ordering from Vans!
