Improved big block valley pan?
bigbluedodge
6:33 PM
North Branch, MI
I developed an oil leak a few weeks ago on my Charger (499 cu in., .620 lift flat tappet cam, 906 heads) and it turned out the valley pan gasket had cracked. It had seen a lot of passes so I just replaced it. The new one cracked in one race (10 passes). Seems like one of the valves on my headers failed. Anyway, I ordered a another new valley pan and this time got one that's heavier and seems to be plated. The part number was MS960007 I think. I don't remember the number of the first one.
Anybody know anything about the heavier gasket?
Bryand
Is that a Fel-Pro number? A block of soft/sponge rubber will absorb those crack causing harmonics. Wrap it like the factory did with the fiberglass batt. I cannot address the difference in gaskets though.
I threw in an extra 0, sorry. But thanks for the tip on the damping.
Bryand
It's just the standard replacement pan. The felpro 1214 is the same with blocked exhaust ports.
Bryand
I wanted to pm you on your motor build
Bryand
I was wanting to ask you some questions about your motor setup. Please pm me
Bryand
If your using header evac and a valve fails, it will crack the stock type valley pans. I don't know if the metal thickness is different?
I usually use the Fel-Pro 1214/1215 without the exhaust crossover cutout.
I'll be happy if that's the problem. I was worried because the engine has plenty of runs on it but runs the number and all signs are good.......except cracking the valley pan. I'ss
I'll be happy if that's the problem. A friend at the track suggested that may be the trouble. I'll find out this weekend.
Bryand
I made this quit a few years ago to eliminate the valley pan gasket with iron heads. it works.
Holy smokes! I just came across this. Very nice custom work! Any photos of it installed? Does it really seal out in oil well? I know iron heads aren’t one flat intake surface
It works pretty good. It's made to have a " slight" snap in. I seal the end rails with rtv and the side wings fit into the iron head cut outs. The wings are rtv'ed in and i never experienced oil leaks. I'm might be able to get a pic of it sitting in an engine i'm mocking up.
The flat covers vendors sell only work with aluminum heads.
Welp… if it’s not leaking from the wings, you’re good to go, nice work! I just wish someone would step up and build an integrated intake with valley pan, like small blocks, or the MP max wedge intake. The tin pan works, just seems like an excuse not to build a better intake
I’d wager if MP sold this at a competitive price for standard port, it would sell very well. I’d buy one.
People have modified intakes to create a valley seal. Very doable if you have some time/ patience and a tig welder. Doing what i did is probably simpler and makes intake manifold changes easier. What i did actually isolates the oily valley from the ports: modifiying an intake manifold won't. My goal was complete isolation from oil.
