727 rebuild help
dan juhasz
5:00 PM
Whiting NJ
So I’ve located a correct part number trans for my A12 a 093 core 69 440 hp unit. Disassembled it today. Need advice on several things I see , some I know is bad others not sure what the issue is.
Please forgive me if I get the name of assembles wrong. I’m capable to follow directions and have rebuilt one other 727 that came out fine but I do not know all the nuisance.
The clutch assembly with the bellvue spring has four clutches, everything seems normal. The other clutch assembly has a standard .068 steel directly on the aluminum piston . Activating that 4 clutch pack. That steel is all bent up out of shape. And every steel in that assembly has hot spots all the clutch show uneven wear. Shouldn’t it have a much thicker .250/.280 steel directly on that piston? Shouldn’t it have it have 4 clutches or only 3. I think someone wanted four clutches and tried something dumb.
Next low reverse drum has heat spots all around , clean it up and use or replace?
Rear output shaft support looks like it was starting to fall and loose aluminum, replace correct.
The metal tab behind the sprag outer housing. Many of the spring tabs were bent fully compressing the springs. I was going to buy a bolt in sprag from Cope.
I measured overall input shaft clearance before disassembly, .130 only had one fiber washer and clip. Fiber was appears really squashed.
Appreciate all input, pictures below.
Also has an area in pan rail that was either cast that way or damaged. Should I get it welded up and machined down level?
One of the heavy .280 steels looks pretty blue, toss it?
That trans was abused. I suspect a poor valve body timing, and bad driver error for a long time.
Shop for 727 parts at A&A transmission, not the other place.
Yes the rear support, sprague, and rear drum are junk. Is the .280 steel normal or smoked on the other side? Is it flat or warped?
Yes a thin steel goes on the piston. It has backing from the piston. You need a thick plate on top because the only backing pressure is the snap ring on the edge.
Should have 2 fiber washers in the front drum area. They should be flat and not steps or ridges. And also the little washer on the output shaft.
Yes it did have 4 clutches in the front drum when new.
I was building trans for a guy racing mid 10's. He needed a trans and all we had was 3 clutch drum so he used it. He has a manual valve body so max pressure all the time. It never failed.
That thick steel that shows the blue was towards the snap ring other side looks normal.
If said plate is flat, clean it and reuse it putting clean side towards the disc, make sure its FLAT
Drum pistons push against thin steels. Goes thin steel, disc , thin steel , disc etc etc etc
The thicker steel ( aka reaction plate ) is outside , next to snap ring
ANY steel thats not flat is toast
Yes your stator support and low rev drum are toast
From what I can see , your case is fine
ps, why is the outer sprag ring out? Its staked in place
If it is that easy to r+r ,,,youre probably gonna need a bolt in sprag to save the case
All the fingers on the sprag were bent compressing some of the springs. I loosened the set screw and through the rear support bolt holes I gently tapped it out. I intend to install a bolt in sprag.
