I am curious as to how much better/cooler a dedicated trans cooler (external radiator) is over an aluminum engine radiator with the two lower likes in stock config?
No doubt an auxiliary cooler can lower temperatures. Question is do you really need one? Most cars rely on the standard radiator cooler with no issues. Unless I had a need to run one I would run with the stock system. KISS theory.I am curious as to how much better/cooler a dedicated trans cooler (external radiator) is over an aluminum engine radiator with the two lower likes in stock config?
My original set up was great. I am contemplating a higher stall converter. Temp ~ life with trans and torque converters. Just curious if it’s worth it…. It surely doesn’t sound like it will hurt.No doubt an auxiliary cooler can lower temperatures. Question is do you really need one? Most cars rely on the standard radiator cooler with no issues. Unless I had a need to run one I would run with the stock system. KISS theory.
If I was concerned about heat the first thing I would do before wasting money is install a temperature gauge so I know what the transmissions fluid temperature is.My original set up was great. I am contemplating a higher stall converter. Temp ~ life with trans and torque converters. Just curious if it’s worth it…. It surely doesn’t sound like it will hurt.
Where would you put the thermostat at?If I was concerned about heat the first thing I would do before wasting money is install a temperature gauge so I know what the transmissions fluid temperature is.
Most put them in the pan. Weld a bung or get a deeper pan that comes with a bung. Plus a deeper pan will add a couple more quarts which can help it cool.Where would you put the thermostat at?
Check so an additional tapped hole huh?Most put them in the pan. Weld a bung or get a deeper pan that comes with a bung. Plus a deeper pan will add a couple more quarts which can help it cool.
Yes. But make sure the wall is thick enough. If not have someone tig weld up a lower area so you have more meat to drill and tap. Do a google search for aluminum pans to see where they add a lower bung/port.
