KnoGood
Hello Folks,
Perhaps someone can help me. I am about to take shipment of a nicely built 440 to go into my 70 Charger but when reviewing the engine photos noticed that an Eddy 440 RPM manifold was bolted up. The dyno sheet with that combo showed great torque from 3100 to 4600 at 500 ft lbs +/- 10 and peak hp 442 at 5400 - lovely.
Long story short, does anyone know if I can make this fit under my hood? I will be running a quickfuel 780v carb so maybe a drop base air cleaner can help. I just dont want the engine shipped to me and finally no solution can be found (replace intake etc....) I would greatly appreciate a quick reply.
The only other solution would be to crank up the car via torsion bar - but that can't be it right??
Thanks in advance
Thanks in advance
