View attachment 421343 https://www.summitracing.com/parts/lak-15905
You can make the rest. It bolts on housing and pin goes into starter to hold it in place. I made mine, as you see not available. Since the cup is there the rest is pretty easy. Isn't the one I made but this is it. Small part of pin goes into starter and the larger part of pin holds it against shield.
