SOLD Lakewood (?) Bellhousing
Kevlisa
7:47 PM
NJ
Feedback: +1 / =0 / -0
Selling a race style bellhousing for big block. I think it's a Lakewood unit but I'm not sure, I couldn't find a make or part number on it. I think it's 10.5", if anybody can tell me otherwise, please enlighten me. $300.
Looks like a Lakewood to me. Do you have the backplate for it?
if you come down on price I might be interested. shipping to 96750 ?
That is a Lakewood 1-piece scattershield. It will fit either the 10.5" clutch/flywheel or the 11" clutch/flywheel by moving the "starter snout alignment cup" in your bottom right picture. It is currently in the 10.5" clutch/flywheel configuration. When new, they come with a "block plate" that is sandwiched between the scatterhsield & the engine block when bolted up.
On a related note, I used to run a Lakewood 2-piece scattershield because I thought I could take off the "inspection cover" just like a stock bellhousing. That is not the case since to get the Lakewood "inspection cover" off you have to take out the bottom two trans/bellhousing bolts & pull the transmission back, if not completely out. Bottom line, a 1-piece is every bit as good as a 2-piece.
Lakewood for sure, a little pricey without the block saver plate. What happens to all the plates? I see bell housings for sale with out the block saver plate all the time?
https://www.summitracing.com/parts/lak-15905
You can make the rest. It bolts on housing and pin goes into starter to hold it in place. I made mine, as you see not available. Since the cup is there the rest is pretty easy. Isn't the one I made but this is it. Small part of pin goes into starter and the larger part of pin holds it against shield.
View attachment 421343 https://www.summitracing.com/parts/lak-15905
You only need this starter adapter if you're running the 10-1/2" style clutch/flywheel. The 11" size doesn't need the starter adapter.
You could probably make your own block plate if you had to by using the bellhousing as a template & looking at pictures online. I think when people sell these scattershields they've just blown a motor and are in no mood to remove the flywheel to get that plate off.
