Since the cost to come up with a used stock 440 throttle pressure linkage set is expensive, I'm opting to use Lokar's unit as well as the throttle cable. I found a great price on them but I'm wondering, will they need an additional bracket to anchor the cables at the carburetor? I'm considering using the Demond carburetor, which Lokar says you need an additional bracket, which pushes the price up to two hundred bucks for all three units. If I go with the Edelbrock carburetor, can I use the stock anchor bracket? Yeah, I'm trying to go cheap and buy good at the same time.
