I have a 1971 Dodge Charger and just replaced the ignition switch/harness and turn signal switch harness in the steering column. Both were plug and play.The turn signals, hazzards, ignition works great now. It all went in with out a hitch, but now when I hook up the battery the horn is activated? I went back and did it all again and this time I even left the steering wheel off having the turn signal switch exposed and still the horn goes off when I hook up the battery. Have I missed something. The horn was working as it should before I replaced the wiring in the column. Thank you in advance for any suggestions. Happy new year!
