Moparmatt72
Price: $500 local pick up only due to size and weight of it all
Have a twin turbo set up for a small block, includes headman truck headers, feed pipe to turbos flange t4, 60mm waste gates, down pipes and waste gate tubes to run back into the exhaust also included is two air/water intercoolers rated at 600hp each. Was made for a A body but dont see why it wouldn't fit on a B body. Also if you have magnum or the indy lax heads have a support bracket that goes with it.
