plymouthman72
Hi everyone, I am getting to the part of hooking up the brakes in my 72 Roadrunner and am having a hard time finding a set up for my car. My car came with power brakes / front discs and I do not know where to start looking for a replacement power booster set up(my power booster is toast with heavy rust). Everything I have found looks to be a replacement for cars with drum brakes and not cars with front discs. All the kits I have found also require modifications to the firewall as well. To complicate matters, I used a right stuff conversion on the back brakes and will likely need a different proportioning valve but that is a secondary problem. I was hoping someone on here has done something similar and can recommend a power booster that will plug right in. I have no problem going OEM (preferred actually) but again, I'm having trouble finding an OEM style replacement. Any help you guys can give would be much appreciated!
