- 11:38 PM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
No , its a sedan. Lol. But it doesn't have a post, so it must be a hardtop!Convertible
Sounds like it's a four door convertible sedan...lol
Could be an easy fix!
@Stereolab42 do you want to tell me what you are disagreeing with?
Relocating a girl pump/filter is relatively easy fix in my view.
I know you are relatively new and all, but it's common courtesy that if you RED X some to explain your point of contention....not to do what we call a hit and run...
So I would enjoy hearing back from you!
Again like I stated earlier if you want a flawless car without any issues to worry about , you probably need to stick to new cars or those priced a lot (2x) higher than the one mentioned. I don't sweat small stuff nor do I panic at the first sign of something not to my standard... it's a car, it's not brain science or rocket surgery...anything can be fixed...Whenever I've seen a restored car with something so horrendously wrong, it's never that one thing. There are guaranteed to be twenty other things horrendously wrong. So while your claim may be technically correct if read narrowly -- that particular line itself may be an "easy fix" --- the implication was that it might be the only thing wrong with the car. Which I find unreasonably optimistic.
