jpryorx2
hey guys 1st post here. my son and i are in the process of building a 78 magnum for his first car. so far nothing is going rite the body looked good hen i traded my sandrail for it then e found 1.5 inch thick bondo where someone smashed the drivers quarter. bought a parts car and swapped the quarter now were trying to get it on the rotisserie and can't get the k frame bolts out. yeas ago i had a 79 magnum and when trying to change the k frame bushings i snapped the bolts so this time i heated the head of the bolts first hoping the heat would transfer through the threads. 1 did break loose at first but then started spinning in the frame. does anyone have a trick to getting them out? or should i start cutting holes in the side of the frame to get to the end of the bolts?
thanks
jason
thanks
jason
