Not a neutral safety switch ?That switch is the reverse light switch.
What piece is missing ?Nope, neutral safety switch is on the transmission.. Just reverse lights..
This has come up recently in other threads, so I'll jump in here. It is far better to have the neutral safety switch as part of the transmission. If it was part of the linkage, not working, in drive, and you were to say, jumper the solenoid under the hood with a screwdriver, bad things could follow.
All you have in your picture is the outer tube & the reverse light switch... There's no shift tube which would have the tab that actuates the switch, theres no actual steering shaft.. Lots of stuff is missing...What piece is missing ?
I have the shaft and tubeAll you have in your picture is the outer tube & the reverse light switch... There's no shift tube which would have the tab that actuates the switch, theres no actual steering shaft.. Lots of stuff is missing...
Think I'm missing the lever alsoAbsolutely the reverse lamp switch, mine is missing the lever to make it work. I need to come up with a different way, thinking of converting to a later style at the trans
Thanks for the pixsWell since you asked... Here is an exploded view of the steering column. Enjoy. As was stated above.. You are missing lots of stuff.
What does the lever look like ?Thanks for the pixs
If it's not a problem I would like a better pixs. Thank youBlurry picture but this is a 1966 Belvedere column shift column. I can retake the picture if needed but just below the wires you will see the reverse light lever.
