No fire, ready to burn it!
Bubba0
4:47 AM
Ohio
I got the harness laid out and can't get it to fire, 67 GTX, I put a 70's style alternator and a MoPar electronic dizzy in it. I ordered the harness from Year One for those to be plug and play. I get 6.5-+ to the + side of the coil, get a spark when turning the key on and off. Have tried the old known good dizzy, known good old coil. The harness has wires for a 4 terminal ballast that reads ohms correct and a newer style voltage regulator. Should fire right? Do I have to move some wires in the block maybe?
Show a picture of the back of the ign. switch. Also is the manual or auto trans?
pin 1 at the ignition box should be hot from the dark blue wire from the ballast resistor in run only. It should be hot from the brown wire at the ballast resistor in crank only. If it loses voltage in either key position repair that circuit. Read here
https://www.allpar.com/fix/electronic-ignition.html
Check the two as DVW suggested.
And those vice grips look kinda sketchy.
Maybe put a rubber mat or something below them, or just a bolt and nut through the two wires for now.
Let's hope it's not another bad ECU there has been quite a run of crap lately.
New paint? Maybe a poor ground at the ign box? Check all the pins at the bulkhead. The new ones need a good push because of the new foam gasket.
Do something with the vise grips before you burn it up.
You will need 10V or more for the ignition box to fire.
That's how it is wired, can I get by pass the ballast temporary to eliminate it? It test like it should.
Does it matter the coil, read something they are different for electronic ign and points. But I tried with the old coil and it was good before the car was disassembled. I have a yellow Blaster coil on it
Can I use a 4 pin ECH with a 4 terminal ballast?
It should work with either coil.
And yes you can use the 4 Pin ECU with the 4 terminal ballast, it's just that the one resistor in the ballast is unused.
Try a temporary ground on the ECU, then a different ECU provided you have power during crank and run at the right pins.
Let us know how you make out.
Had this issue in the past after adding electronic ignition, problem was the plug for the distributor was not making a connection.
I had a similar issue but mine is a manual so ignition 2 is spliced I to ignition 1 in order to get full voltage to starter and the rest of ignition system. At first I only had ignition 1 hooked up and was only getting 6 volts at coil. On an auto I believe ignition 2 is part of the neutral safety switch circuit but not sure.
Got it figured out, my fault. Bought new bulkhead block, 2 brown wires one with a stripe , was backwards. Be glad when this money pit is done. :)
Thanks for the help.
I maybe wrong but if this is an automatic why is the starter relay for a manual with the yellow wire or am I loosing it?
Not losing it... To late, already lost it...:poke::lol: The yellow wire is from the ignition switch... The brown wire goes to the neutral starter switch on an automatic, on manual starting I believe in 70 it goes to the clutch switch... The brown wire provides a path to ground for the control side of the starter relay...69 & earlier manual trans had a different design relay with no connection for the brown wire instead the control side of the relay was internally grounded... Picture below..
