Lazybird21
Hello,
do i need the special swap engine mount (from classic industries or schumacher) to install a b-engine in a 74 small block roadrunner? Or is it possible to use the standard 74 big block mounts anyhow? I already noticed that it wont be plug&play when i tried to fit the engine into the engine bay.
Is it possible to modify the big block mounts to match the small block k-member?
I wasnt aware before that there are different k-members in the 73/74 models.
