Can someone identify this steering column
Car #4
1:08 PM
Ontario
I need help identifying this column. Year, model, floor shift?, column shift?, Auto?, Manual?, power steering?, manual steering?. What's it worth? Thanks for your help.
IMG_2280.jpg IMG_2281.jpg IMG_2282.jpg IMG_2283.jpg IMG_2284.jpg IMG_2285.jpg
Looks like the column in my Charger, floor shift column
67-69, floor shift, if the pictures can be taken as accurate, probably power steering.
It is earlier than a 1970. No ignition key.
67, first year for collapsible column.
@Jerry Hall Pictures are accurate, I just took them. What identifies it as a 67? Just trying to learn. Thanks.
Shorter shafts on power steering since the steering gear is physically larger.
I just noticed the wiring connector, not a 67 from that viewpoint. 68-69, or when they switched from the flat connector.
Just joined. Do you still have this column? I would like to buy or trade. I think the only year was 68 without ign switch in column. I have a really nice ps fs one with ign switch in column for trade. Might be able to possible throw an a body man one too
Yes I still have it. Where do you live?
wrong lower bearing for 67 so 1968 or 69 B body column looks short,, so would say power steering column
