Mopar Shah
Hello guys! Thank you in advance for your advice. I have a 65 plymouth Fury donor car which has a 8 3/4 rear end in it. I need it for my 68 coronet. I checked the sizes and apparently the Fury rear is only 1 inch wider than a 68 coronet.
Can I swap the 65 Fury 8 3/4, into the 68 Coronet with some modification? What modifications would it need if it can fit?
thank you again!
thank you again!
