old guys rule
I've been hearing a lot of guys complain about the orange ignition module being unreliable. What's everyone using as an alternative?
There was a gentleman on here selling the old orange (80’s units NOS) you could search it out or I could find it in my pics laterI've been hearing a lot of guys complain about the orange ignition module being unreliable. What's everyone using as an alternative?
Prob the best replacement made now.It can be said that if you have a newer orange ECM in the car, you should also have comfortable socks and shoes.
I had a chrome box for years, it crapped out recently. I now have this:
YES.....THE BEST ALTERNATIVE IS TO REVERT BACK TO POINTS AND CONDENSER METHOD.......realizing you will lose 50+ blazing HP and increase in MPG, etc. Everything promised with ECU is smoke and mirrors.....I've been hearing a lot of guys complain about the orange ignition module being unreliable. What's everyone using as an alternative?
I wish the red x was still available. I’m guessing you also think bias ply tires are still the cats meow? Are you typing this using a telegraph? Do you even have a starter on your car, or do you use the hand crank still?YES.....THE BEST ALTERNATIVE IS TO REVERT BACK TO POINTS AND CONDENSER METHOD.......realizing you will lose 50+ blazing HP and increase in MPG, etc. Everything promised with ECU is smoke and mirrors.....
BOB RENTON
I run points and condenser, but if you don't use NOS parts, you're exposed to the same quality issues that accompany electronic ignition components.YES.....THE BEST ALTERNATIVE IS TO REVERT BACK TO POINTS AND CONDENSER METHOD.......realizing you will lose 50+ blazing HP and increase in MPG, etc. Everything promised with ECU is smoke and mirrors.....
BOB RENTON
Especially condensers. The new ones are garbage. I run points in my dual point in my 66. I get my tune up parts from Halifaxhops and yes I have bought extras. I have a simple Pertronix in mysingle point 70 distributor. It has been flawless for years.I run points and condenser, but if you don't use NOS parts, you're exposed to the same quality issues that accompany electronic ignition components.
I use a pull rope to start.....and magneto ignition....works every time.....nothing wrong with bias ply tires....let's have a "thinking" contest or compare check book balances .......what ever your real name is......I wish the red x was still available. I’m guessing you also think bias ply tires are still the cats meow? Are you typing this using a telegraph? Do you even have a starter on your car, or do you use the hand crank still?
Are you trying to say check books determine how something works?compare check book balances
You are entitled to your opinion......and i have mine......no.....except my net worth is FAR greater than yours....and I'm laughing at you......your turn.......Are you trying to say check books determine how something works?
You’re a joke man
