‘70 Satellite 318 to 440 torque box upgrade necessary?
LowlySatellite
3:04 AM
East Tennessee
My ‘70 satellite originally had a 318 with an automatic transmission and open rear diff. I’m going to upgrade to a 440 four-speed with a limited slip rear diff supported with new, upgraded rear leaf springs.
I do NOT plan on drag racing this car with big sticky slicks on a prepped track. But, I DO plan on hammering down occasionally on the street with some 275 wide rear tires.
Do I need to do anything to the stock torque box area bracing to prepare for the 440?
My 68 Coronet originally had a 318. It’s had a 440 and now a 528 hemi with a 4 speed. It hasn’t had a 318 for probably 25 plus years. I don’t have torque boxes added to my car. Mine is only a street car but I have flogged it. I’m not aware any issues so far.
Great, thanks for the information.
I installed spring hanger reinforcement plates on my 440 4 speed car, you can get them at Hughes engines and Mancini Racing for about $25.00
Necessary? No. A good improvement? Yes.
What really helps are weld in subframe connectors tying the front to the back.
I don’t see any reason why you need to. I believe hemi cars and convertibles were the only cars with factory torque “boxes”
Not True. My 72 RR has them. It is a factory 440 car and many other 440 and 440-6 cars had them..
Chassis reinforcements do more than just reduce flex. They also reduce vibrations and noise even when you're not pushing the car hard. Smoother ride, less noise and a better driving experience.
I have the plates and plan on the boxes. Have SS springs 73 Duster BB auto 391s SG. Street/ strip and our track is set to reopen Mid May after 3 years. WooHoo..
Interesting. were they all equipped with them or were they a special order by the customer?
It's crazy how some got them and some didn't. Lazy or haphazard assembly line workers? 6 pack cars and convertibles should have them front and rear. 440 4 barrel cars may have both or just fronts or just rears. Like the A body cars, 340 4 speed car should have them on all 4 corners but many didn't. If they were on one end or the other they were usually on the fronts only. But not always.
Don't know much about the A-bodies but the B-bodies were pretty consistent from what I have seen over the years.
