- 3:22 PM
- Apr 13, 2012
- Granite Bay CA
The 2.71 gear in an 8 1/4” axle is not a simple change like going to a different gear in an 8 3/4” axle.
This is a daily driver gear in a 3500 lb car. Torque is needed to get a heavier car moving. I don’t see how an engine will make more power after it breaks in. Better fuel economy and reduced oil consumption yes but power increase? I don’t see it.
A big block swap does mean a different transmission, drive shaft, exhaust from engine to H pipe, some slight changes to wiring along with almost everything attached to the engine. The P/S pump will interchange but the mounting brackets won’t. The distributor cap is the same, the distributor isn’t.
I agree though that even a 5.9 Magnum/360 with the longer stroke would be a lot easier to do. I built a 1990 roller cam 360 for a 67 Dart that runs like hell but it is a lighter car with a 4.10 gear.
