1962 8.75 (tapered) axle shaft seal numbers
62 Dart Convertible
1:29 AM
Australia
Does anybody know for sure the numbers for the inner and outer axle shaft seals. I have been scouring the net and seen so much conflicting information I don't know what to believe...
(Currently fitted inner is 470487N which I'm pretty sure is right, and outer is 8133S which I'm not so sure is right.)
Help would be much appreciated!!
Here you go, NAPA #'s are 13500 the outer axle seal. 15207 is the inner.
After much cross-referencing and measuring and help from you, I am now sure I have the right seals. Thanks very much for the help guys.
For the record, from my research, inner seal 15027 and 470487N are the same. Outer seal CR13500 and 8133S are the same too.
