Getting close to completion.
X10WOW!
looks awesome with the white wall tires . they where the thing to have back then
Looks great, I need a larger garage for all my 62's.
This is your side molding clip. I'll keep looking as well. Let me know if you find them! Great car by the way!'62 in my garage also.. but i went the opposite direction and made mine worse than when i started(having a hard time finding clips for the fender trim)
I think your right. It uses a combo of type of clips. Of course I only took pics of the one I couldn't find! Most you can get to the nut on the back. The one I have pictured was like the last two that you can reach the back (last two before the door starts?)Thanks.. i have my old ones but they are not very good... might just use them.. would i would like to find are ones that use a nut on the back instead of just pushing through.,. gonna see if i can find something later today..
Thats what i ended up doing on the quarter trim where it had just plastic clips that snap if you touch them...
yup.. i have 4 of the spring clips, they just aren't holding as tight as i would like.. and you know how easy it is to find trim for a 62 if something goes wrongI think your right. It uses a combo of type of clips. Of course I only took pics of the one I couldn't find! Most you can get to the nut on the back. The one I have pictured was like the last two that you can reach the back (last two before the door starts?)
Is the Belvedere Trim same as the Dart? I know Savoy is different.yup.. i have 4 of the spring clips, they just aren't holding as tight as i would like.. and you know how easy it is to find trim for a 62 if something goes wrong![]()
nope.. they are all different.. savoy/fury/belv.. at least the fender piece is.. but it might also be option based not level based...Is the Belvedere Trim same as the Dart? I know Savoy is different.
