Anselmi
I'm doing a restoration on a 1963 MW Savoy, scheduled build date 10th of December (actually shipped allready on the 6th) 1962. At some point the inner fenders had been cut off, so a pair from a donor car needs to be used. Donor fenders have some extra holes, some added by previous owners some clearly from the factory. If someone could tell me what the driver side fender holes K, L and M are used for, I would be very thankfull.
Also I have a theory that they (K, L, M) appeared somewhere between February-April 1963, which would mean that I should weld them shut to be "correct" for my December 1962 build car. So if you 1963 owners could tell if you have those holes or not, accompanied with the scheduled build date (found on the bottom row of the fender tag, the first 4 numbers).
I might be wrong thinking that the holes are related to the build date in any way. But there was certain changes in March 1963 which in my mind might point into this direction.... thanks for the help :sSig_thanks:
